Ga door naar hoofdinhoud
How to restore a shrunken sweater
Wat je nodig hebt
  1. How to restore a shrunken sweater, How to restore a shrunken sweater: stap 1, afbeelding 1 van 1
    • Add 2/3 full of water into the washbasin.
    • Add 20 ml of Baby Shampoo into the washbasin.
    • The volume of water needed depends on the size of the sweater. The larger the sweater, the more water needed.
  2. How to restore a shrunken sweater: stap 2, afbeelding 1 van 1
    • Soak the sweater into the washbasin with soapy water for 15 mins.
  3. How to restore a shrunken sweater: stap 3, afbeelding 1 van 3 How to restore a shrunken sweater: stap 3, afbeelding 2 van 3 How to restore a shrunken sweater: stap 3, afbeelding 3 van 3
    • Take out the sweater from the washbasin with soapy water.
    • Remove the sweater to the bucket filled with fresh warm water.
    • Rinse the sweater thoroughly.
  4. How to restore a shrunken sweater: stap 4, afbeelding 1 van 1
    • Take out the sweater from the bucket.
    • Wring the clothes gently to get excessive water out.
  5. How to restore a shrunken sweater: stap 5, afbeelding 1 van 1
    • Place the sweater flat in the center of the bath towel.
  6. How to restore a shrunken sweater: stap 6, afbeelding 1 van 3 How to restore a shrunken sweater: stap 6, afbeelding 2 van 3 How to restore a shrunken sweater: stap 6, afbeelding 3 van 3
    • Roll while wringing the towel together with the sweater in order to dry the sweater.
    • Redo the process for a couple times until the sweater is dry to the touch.
    • Unfold the towel and take out the sweater
    • Spread out the sweater flat and let it dry.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Zhou Zhou
148 Reputatie
1 Handleiding geschreven
UC Davis, Team S2-G8, Bender Fall 2018 Lid van UC Davis, Team S2-G8, Bender Fall 2018
UCD-BENDER-F18S2G8
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 422
