Wat je nodig hebt
Press Esc on the keyboard, and select BIOS Setup (F10). Select Restore settings to factory default. The computer will restart and then you may be prompted to enter a code. THIS IS EXPECTED BEHAVIOR IF IT OCCURS; there is a presence option in the HP commercial BIOS.
Once the settings have been reset, there will be no setting related issues to worry about.
Press Esc on the keyboard, and select BIOS Setup (F10). Select the Security tab and select Restore settings to factory default. The computer will restart and then prompt for a code to reset the TPM. THIS IS EXPECTED BEHAVIOR. The code will only work one time as it is randomly generated.
Once both the BIOS and security settings are reset, you are ready to install an operating system.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Reset security defaults (023)
3670 + enter - to complete the change
Esc- continue without changing
For more information, please visit: www.hp.com/go/tech center/startup
Need to know how to get out of this. I want to save the change
Please help
