Wat je nodig hebt
It is advisable to work with two people, one holding the outer handle on the outside and the other unloading the screw on the other side.
Remove the two screws.
Use pry bar carefully pry around, you can remove both sides of the door handle.
Reversing the steps to know hot to install the know. It's easier than your thought , isn't it?
5 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
