Inleiding
Hey there!
On this guide, I will show you how to remove a broken towel hook on drywall, patch the hole, and install a new one!
Before you start, make sure you have the required tools and be careful around the screwdriver!
This guide will not take long, only around 10-15 minutes, but you’ll have to come back to this a few hours after you’re done installing the new hook to clean up the old hole.
Happy Fixing!
Wat je nodig hebt
Using your Phillips screwdriver, remove both screws that are keeping your current (broken) drywall hook in place.
This guide shows both removing the old, broken towel hook and installing the new towel hook! Hope it helped!
Één andere persoon heeft deze handleiding voltooid.
