Inleiding
This guide will teach you how to remove the casing, remove the pin of the pedal and replace the spring for the pedal. You will need a medium sized Phillips screwdriver and an all-purpose wrench (although any small flat wrench will work).
Wat je nodig hebt
Close the casing again and fasten the casing with the screws. You have now successfully replaced the spring!
