Inleiding
Cheap fog machines are often damaged because of poor quality. Most of these damages can be easily repaired. This guide can be used to repair the more common problems that can be encountered when dealing with this type of fog machine.
The fog machine I repaired is called 'eurolite n-19', but it is also sold under other names.
Onderdelen
Geen onderdelen nodig.
  1. Open the fog machine by removing the screws at the sides of the fog machine with the screwdriver
    • Open the fog machine by removing the screws at the sides of the fog machine with the screwdriver
    • Remove the outer casing of the fog machine.
  2. If the fog machine does not heat up the fuse or another heating element could be malfunctioning
    • If the fog machine does not heat up the fuse or another heating element could be malfunctioning
    • If there is nothing coming out of the fog machine the pump of the fog machine could be malfunctioning
    • Detailed info on finding out what's wrong can be found at: tec-shack's fog machine repair guide
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  4. Acquire the necessary tools for repair
    • Acquire the necessary tools for repair
    • In this instance, all that was needed was a new heat fuse and new spade connectors
      • Remove the heat fuse
      • Remove the spade connectors
    • Connect the new heat fuse and spade connectors to their respective locations
    • The heat fuse sits under the bimetal. (Cannot be seen clearly in the picture)
  5. Simply reverse these instructions to reassemble the fog machine.
    • Simply reverse these instructions to reassemble the fog machine.
Conclusie
4 andere personen hebben deze handleiding voltooid.
rjay
206 Reputatie
1 Handleiding geschreven
My fogger heater is jam how can I clean it?
vishal_kishor777 - Antwoord
hmm… I think I could have written a better guide myself. Okay so I have a 3 pin XLR for phase does anyone know how this works also I noted that the fuse was melted into its holster and the pump seems dead. My Fogger also has some kind of potentiometer which controls the heating element which is like a ceramic sandwich and two spark plugs… I also was wondering if glycerin fog juice can be made with vegetable glycerin or the glycol type or if this is what cloggs the machine. Also will clr work or be dangerous fume wise? Can you market glycerine as fog juice thickener like STP fuel additives for cars?? g0pg.xyz is my website you can learn how to force push graphite if you look for the post with yoda!
Ember Leona - Antwoord
Where can I buy a fuse like this? Have looked over the net, but could not find any shops that would sell CH-15 fuse, used in this fog machine. If anyone knows about this, please share info. Thanks! By the way, I’m based in EU.
Giedrius Stasiulis - Antwoord
My fog machine is not pumping out smoke
Ohwaga Kerry - Antwoord
No power to my fog machine ?
David McCartie - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 18
Afgelopen 7 Dagen: 117
Afgelopen 30 Dagen: 501
Altijd: 39,054
