Ga door naar hoofdinhoud
How to repair an iPhone that won't charge - Tristar Replacement
Wat je nodig hebt
  1. How to repair an iPhone that won't charge - Tristar Replacement, Check for a new charger: stap 1, afbeelding 1 van 1
    • Your cable could be bad, try a new one, possibly MFI certified ! (Made For iPhone) Or try a known-good one.
    • Try a new charging brick, or a known-good one that delivers at least 5V-1A
  2. How to repair an iPhone that won't charge - Tristar Replacement, Checking the charging port: stap 2, afbeelding 1 van 1
    • Check your charging port, it could be really dirty or obstructed
    • If it looks dirty, you can take the risk to insert a thin tool and try to pry out the dirt. I am not responsible for the harm you could do to your phone !
  3. How to repair an iPhone that won't charge - Tristar Replacement, Try known-good internals: stap 3, afbeelding 1 van 1
    • Try a known-good battery. Replace it if your phone charges again.
    • Try a known-good Lightning charging port. Replace it if your phone charges again.
    • I know, this is a picture of an iPhone 7, check the video for the 6S on the next step.
    • The whole french version of the process, video does help if you are an english-speaker !
  4. How to repair an iPhone that won't charge - Tristar Replacement, Now some real challenge: stap 5, afbeelding 1 van 2 How to repair an iPhone that won't charge - Tristar Replacement, Now some real challenge: stap 5, afbeelding 2 van 2
    • If you are still reading, bad news, you probably have a motheboard problem !
    • It's probably U4500, or Tristar that's causing it, it fails very frequently on iPhones. You'll have to replace it.
    • Video tutorial for Tristar replacement on iPhone 6S
Conclusie
12 andere personen hebben deze handleiding voltooid.
Alexandre Isaac
2.887 Reputatie
8 handleidingen geschreven
The Repair Academy Lid van The Repair Academy
Business
1 Lid
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 44
Afgelopen 30 dagen: 155
Altijd: 11,182
