Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Using your Phillips #0 remove two 12.7 mm screws on each side of the door.
Remove the door.
Using the Phillips #0, remove three 25.4 mm screws that hold the lint trap to the dryer.
Remove the lint trap. You can see that there is a lot of lint in there. Once you take off the lint trap, you need to move it to the side. That way you have access to the trap and all the lint.
Use your hands to clean out all the lint from the trap. Grab all the lint inside the trap.
Use an attachment to vacuum the remaining lint out of the trap.
Use a washcloth and wipe down the trap and clean it.
Replace the lint trap and using the Phillips #0 screwdriver, screw the three 25.4 mm screws to secure the lint trap.
Using the Phillips #0 replace the four screws for the dryer door. Each side has two12.7mm screws.
