Ga door naar hoofdinhoud
How to repair a hole in a crochet dishcloth
Wat je nodig hebt
  1. How to repair a hole in a crochet dishcloth, How to repair a hole in a crochet dishcloth: stap 1, afbeelding 1 van 1
    • Collect the tools and materials you'll need.
  2. How to repair a hole in a crochet dishcloth: stap 2, afbeelding 1 van 3 How to repair a hole in a crochet dishcloth: stap 2, afbeelding 2 van 3 How to repair a hole in a crochet dishcloth: stap 2, afbeelding 3 van 3
    • Identify any loose loops that may come undone if any yarn is pulled.
    • Put a safety pin through the loops, this will prevent the hole from getting any bigger.
  3. How to repair a hole in a crochet dishcloth: stap 3, afbeelding 1 van 3 How to repair a hole in a crochet dishcloth: stap 3, afbeelding 2 van 3 How to repair a hole in a crochet dishcloth: stap 3, afbeelding 3 van 3
    • Pick one of the loose strands and tie the yarn to this strand.
    • Make three knots to ensure the knot will not come undone.
  4. How to repair a hole in a crochet dishcloth: stap 4, afbeelding 1 van 3 How to repair a hole in a crochet dishcloth: stap 4, afbeelding 2 van 3 How to repair a hole in a crochet dishcloth: stap 4, afbeelding 3 van 3
    • Begin your first stitch by pushing the crochet hook through the stitch closest to the tied on yarn.
    • Next, wrap the yarn in front of the hook and pull it through the stitch making sure the hook catches the yarn.
  5. How to repair a hole in a crochet dishcloth: stap 5, afbeelding 1 van 3 How to repair a hole in a crochet dishcloth: stap 5, afbeelding 2 van 3 How to repair a hole in a crochet dishcloth: stap 5, afbeelding 3 van 3
    • Continuing on your first stitch, wrap the yarn in front of the hook and pull it in the direction of the arrow through the loop wrapped around the crochet hook.
    • Move on to the next stitch where the orange arrow is pointing. Continue making stitches around the hole until there is a small opening.
  6. How to repair a hole in a crochet dishcloth: stap 6, afbeelding 1 van 3 How to repair a hole in a crochet dishcloth: stap 6, afbeelding 2 van 3 How to repair a hole in a crochet dishcloth: stap 6, afbeelding 3 van 3
    • Once you have a small opening you will now close the hole. Using the same stitch used throughout the guide, make a stitch interlocking every other stitch.
    • The crochet hook should be moving in the direction the arrow is pointing.
  7. How to repair a hole in a crochet dishcloth: stap 7, afbeelding 1 van 3 How to repair a hole in a crochet dishcloth: stap 7, afbeelding 2 van 3 How to repair a hole in a crochet dishcloth: stap 7, afbeelding 3 van 3
    • Continuing until the hole is completely closed.
    • Cut the yarn leaving about a 4 inch tail.
    • Pull the loop in the direction the arrow is pointing.
  8. How to repair a hole in a crochet dishcloth: stap 8, afbeelding 1 van 3 How to repair a hole in a crochet dishcloth: stap 8, afbeelding 2 van 3 How to repair a hole in a crochet dishcloth: stap 8, afbeelding 3 van 3
    • Using the large threading needle, thread in all of the strands of yarn.
Conclusie
Rayme Ivers
157 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G8, Cardinal Spring 2020 Lid van UW Tacoma, Team S1-G8, Cardinal Spring 2020
UWT-CARDINAL-S20S1G8
1 Lid
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 55
Altijd: 2,924
