Inleiding
Power button of LG G5 has the function of fingerprint scanner. Follow this video to repalce the broken fingerprint sensor of LG G5.
Wat je nodig hebt
Video-instructies
Bijna klaar!
Conclusie
14 andere personen hebben deze handleiding voltooid.
12Gids Commentaar
Does this cover the power button not functioning? The fingerprint but is vibrating but wont turn the phone on?
mrs_johnson79 - Antwoord
My power button had been working only intermittently and then almost not at all. The solution was amazingly simple. I wet a Qtip with alcohol and rolled it around the edges of the button, pushing in as much as I could. Each time I did that the button started working better and better. Now it works perfectly. I think between humidity, finger oil and dust, it just got dirty inside.
Simintov - Antwoord
This alcohol qtip comment helped. Button works again!
Sarah Young - Antwoord
I had the same problem with my LG G5. I was very skeptical about the alcohol qtip idea but was all out of ideas and decided to give it a try. After rubbing it with the qtip for about 5 seconds the button started to work again. Unbelievable! Thanks for the great tip.
Craig Meyer - Antwoord
Well %#*@. The alcohol and q-tip trick worked! I’m floored. I’ve been double-tapping since two months after I got the phone. I used cleaning alcohol, like that for wounds (70%), and pressed the button in with the saturated q-tip while scrubbing around and on the edge. As the above comments mentioned, repetition resulted in increased success: I used a total of one and a half q-tips, and applied alcohol about 3 or 4 times. No disassembly required.
Alexandra Ramsey - Antwoord
