Ga door naar hoofdinhoud
How to remove top vent of Winix C535
Wat je nodig hebt
  1. How to remove top vent of Winix C535, Locating the tabs: stap 1, afbeelding 1 van 1
    • I suggest starting from the middle, popping it out just a tiny bit and move outwards to the sides
    • Apply a small constant lift should make removing this easier. Similar to disassembling other plastic encasements.
  2. How to remove top vent of Winix C535, Taking it out: stap 2, afbeelding 1 van 2 How to remove top vent of Winix C535, Taking it out: stap 2, afbeelding 2 van 2
    • It pulls towards you a little bit to loosen up and then comes out by moving it forward once it's in this position.
    • Clean the vent and reassemble by inserting it from the bottom first and then clicking in the tabs in the front.
  3. How to remove top vent of Winix C535, Done: stap 3, afbeelding 1 van 1
    • Well that was easy wasn't it? Back to making it eat wildfire smoke and whatnot when the time comes.
    • Also do keep in mind that "PlasmaWave" is an ionizing tech which creates ozone in small amounts (regardless of what manufacturer says), so don't use it that often. If you do, you need to air out the room/house when the outside air is cleaner.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ray
127 Reputatie
1 Handleiding geschreven
1Gids Commentaar
thank you very much
Thusy Veeram - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 52
Altijd: 2,091
