Ga door naar hoofdinhoud
How to remove the Samsung LA40R81BD 40in LCD TV rear cover
Wat je nodig hebt
  1. How to remove the Samsung LA40R81BD 40in LCD TV rear cover, Rear Cover: stap 1, afbeelding 1 van 1
    • Unplug power cable and all AV cables from rear of TV and carefully lay TV face down on a clean flat working surface ensuring that you don't damage the LCD screen.
    • Using a Philips driver remove the 18 screws from the rear panel.
    • Gently lift the rear cover off the TV. You may need to wiggle the cover a little however there are no clips holding the cover on so it should come off easily if you have fully unscrewed all 18 screws.
Conclusie
11 andere personen hebben deze handleiding voltooid.
Richdave
32.051 Reputatie
30 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.521 handleidingen geschreven
3 opmerkingen
Got cover off but how to unplug the wires
cpeeledc - Antwoord
What size screws holds on the rear panel?
D Mack Miller - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 37
Altijd: 24,114
