Ga door naar hoofdinhoud
How to remove scratches from an Airpods Case
Wat je nodig hebt
  1. How to remove scratches from an Airpods Case, How to remove scratches from an Airpods Case: stap 1, afbeelding 1 van 2 How to remove scratches from an Airpods Case, How to remove scratches from an Airpods Case: stap 1, afbeelding 2 van 2
    • The front and back are already scarred.
  2. How to remove scratches from an Airpods Case: stap 2, afbeelding 1 van 1
    • Use 2000 grit and above fine-grained sandpaper.
    • For this tutorial, I used 2500 grit directly and then 3000 grit for a finer finish.
    • Careful when choosing a grit, a too coarse sandpaper grit will damage the airpods case
  3. How to remove scratches from an Airpods Case: stap 3, afbeelding 1 van 1
    • Cotton wool and medical alcohol are used to clean the surface of the charging case.
  4. How to remove scratches from an Airpods Case: stap 4, afbeelding 1 van 2 How to remove scratches from an Airpods Case: stap 4, afbeelding 2 van 2
    • Clean the surface of the charging case with absorbent cotton dipped in alcohol.
    • Clean up the inside too!
  5. How to remove scratches from an Airpods Case: stap 5, afbeelding 1 van 1
    • Wet the surface with absorbent cotton or a little water, and then lightly sand it with 2500-grit fine sandpaper.
    • It can be seen that the more serious scratches have been smoothed out, the polished areas have turned white, and the smooth surface has become matte.
    • This step can be performed as many times as necessary.
  6. How to remove scratches from an Airpods Case: stap 6, afbeelding 1 van 1
    • It has now returned to white, but the surface is still matte.
    • If you like this matte style, you can stop
    • To restore a smooth surface, continue sanding with 3000 grit sandpaper in the same way as in the previous step.
    • The finer the sandpaper, the smoother it will be.
  7. How to remove scratches from an Airpods Case: stap 7, afbeelding 1 van 1
    • Refreshed now!
Conclusie
This will give the charging case a refreshed look instead of a dirty, scratched surface.
30 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
zh en
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
Z.Heng
3.802 Reputatie
3 handleidingen geschreven
8 opmerkingen
Extremely convincing, especially the last picture.
Ludger - Antwoord
感谢作者!我的AirPods也布满了划痕!
Zhang Boyang - Antwoord
Kann man auch Polierpaste nutzen wie sie für Kunststoffdisplays benutzt wird?
neo1983-jahn - Antwoord
How big can the scratches be ?
Albert zweisteim - Antwoord
How do you get it shiny again?
lucas cheraki - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 27
Afgelopen 7 dagen: 176
Afgelopen 30 dagen: 595
Altijd: 85,147
