Inleiding
Use this guide to remove the faceplate of your Magnavox MWD200F. Removing the faceplate will allow you to then gently clean the device or complete maintenance repairs. Be sure to unplug your device prior to working on it, especially if you plan to clean it. If you do clean it, gently dust it, and do not use any chemicals on its parts.
Wat je nodig hebt
Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
