Ga door naar hoofdinhoud
How to remove FHX-720bt head unit in a 1999-2007 Chevrolet Silverado
Wat je nodig hebt
  1. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado, How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 1, afbeelding 1 van 2 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado, How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 1, afbeelding 2 van 2
    • Locate the hood latch in your vehicle found on the drivers side under the dashboard to the left of the parking brake pedal.
    • Pull the latch to release hood.
  2. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 2, afbeelding 1 van 3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 2, afbeelding 2 van 3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 2, afbeelding 3 van 3
    • Locate the release latch for the hood in between the grille and hood, directly above the "GMC" logo at the front of the car.
    • Lift up on the latch then raise the hood.
  3. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 3, afbeelding 1 van 2 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 3, afbeelding 2 van 2
    • Locate your battery in the front of the engine compartment near the headlight, on the driver's side.
    • Remove the black negative terminal with 5/16" socket or by using a 5/16" wrench.
    • BE CAREFUL. DO NOT CROSS POSITIVE AND NEGATIVE WIRES.
  4. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 4, afbeelding 1 van 2 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 4, afbeelding 2 van 2
    • Make sure the vehicle is on a flat surface, then use the parking brake.
    • Shift vehicle into 1st gear so the shifter will be out of the way for the next step.
  5. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 5, afbeelding 1 van 3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 5, afbeelding 2 van 3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 5, afbeelding 3 van 3
    • Firmly grasp the top of the dash trim and pull it towards you.
    • Once it is removed from its clips, pull up and the trim will come out the rest of the way.
    • Set the trim aside; you are ready for the next step.
  6. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 6, afbeelding 1 van 2 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 6, afbeelding 2 van 2
    • Remove the face plate from the head unit.
    • To do this, pull out on both the left and right sides to release the face plate from its clips.
    • After being released from the clips, set the face plate aside and continue to the next step.
  7. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 7, afbeelding 1 van 3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 7, afbeelding 2 van 3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 7, afbeelding 3 van 3
    • Remove three bolts using a 7mm socket wrench, two on the left and one on the right.
  8. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 8, afbeelding 1 van 3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 8, afbeelding 2 van 3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 8, afbeelding 3 van 3
    • Remove the head unit once the bolts have been taken out.
  9. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 9, afbeelding 1 van 2 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: stap 9, afbeelding 2 van 2
    • Place the head unit face down to allow the wires on the back to be visible and more easily accessible.
    • Listed below are the wires coming connected to the head unit. The colors correspond to the same color of the wire.
    • RCA inputs
    • Microphone input/wire
    • Power/audio/assorted control wire harness
    • Antenna input/wire
    • Harness disconnect
Conclusie
9 andere personen hebben deze handleiding voltooid.
Justin Reiner
317 Reputatie
1 Handleiding geschreven
Cal Poly, Team 15-1, Green Fall 2015 Lid van Cal Poly, Team 15-1, Green Fall 2015
CPSU-GREEN-F15S15G1
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 28
Altijd: 1,866
