Ga door naar hoofdinhoud
How to recover/reupholster WESC Maraca Headphone Ear Cushions
Wat je nodig hebt
  1. How to recover/reupholster WESC Maraca Headphone Ear Cushions, How to recover/reupholster WESC Maraca Headphone Ear Cushions: stap 1, afbeelding 1 van 3 How to recover/reupholster WESC Maraca Headphone Ear Cushions, How to recover/reupholster WESC Maraca Headphone Ear Cushions: stap 1, afbeelding 2 van 3 How to recover/reupholster WESC Maraca Headphone Ear Cushions, How to recover/reupholster WESC Maraca Headphone Ear Cushions: stap 1, afbeelding 3 van 3
    • Remove the cushion from the headphones by carefully pushing the edges out from the sides of the ear piece.
  2. How to recover/reupholster WESC Maraca Headphone Ear Cushions: stap 2, afbeelding 1 van 3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: stap 2, afbeelding 2 van 3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: stap 2, afbeelding 3 van 3
    • Use a marker to draw an arrow shape around the bottom of the cushion.
    • The arrow's point should fall toward the center of the cushion.
    • The points on the sides of the arrow should extend well beyond the edge of the cushion. They should not be aligned with the corners of the cushion.
    • This is done to ensure that there will be enough fabric to sufficiently cover the cushion.
    • The bottom of the arrow should line up with the sides and bottom of the cushion.
    • Repeat this step to draw a wider arrow for the side of the cushion.
  3. How to recover/reupholster WESC Maraca Headphone Ear Cushions: stap 3, afbeelding 1 van 2 How to recover/reupholster WESC Maraca Headphone Ear Cushions: stap 3, afbeelding 2 van 2
    • Cut out the two arrows of fabric.
    • Using the arrows as guides, cut out 3 additional arrows of each different size. In total you will have 4 top and bottom arrows and 4 side arrows.
  4. How to recover/reupholster WESC Maraca Headphone Ear Cushions: stap 4, afbeelding 1 van 3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: stap 4, afbeelding 2 van 3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: stap 4, afbeelding 3 van 3
    • Attach the tip of the arrow to the inside of the cushion and fold the rest of the arrow over the outside.
    • Using glue or sewing the arrow to the pad will result in a permanent fix, but if you make a mistake you may not be able to undo it.
    • Repeat this step to attach each arrow to the appropriate side of each cushion
  5. How to recover/reupholster WESC Maraca Headphone Ear Cushions: stap 5, afbeelding 1 van 3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: stap 5, afbeelding 2 van 3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    Koop
    • Once you have all of the fabric attached, stretch the edges of the cushion back over the headphone's ear piece.
    • Use a thin plastic card to carefully tuck the edges of the cushion back into the ear piece.
  6. How to recover/reupholster WESC Maraca Headphone Ear Cushions: stap 6, afbeelding 1 van 3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: stap 6, afbeelding 2 van 3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: stap 6, afbeelding 3 van 3
    • Once the cushion has been reattached to the ear piece, use the plastic card to carefully tuck the bottoms of the fabric arrows into the sides of the ear piece.
    • If there is too much fabric to tuck in, use scissors to remove the excess.
Conclusie
Your headphones are now reupholstered and ready to use again.
5 andere personen hebben deze handleiding voltooid.
rss
274 Reputatie
1 Handleiding geschreven
Cal Poly, Team 24-1, Green Winter 2015 Lid van Cal Poly, Team 24-1, Green Winter 2015
CPSU-GREEN-W15S24G1
4 Leden
5 handleidingen geschreven
Één opmerking
thanks for the idea! but I have to say this was a lot harder & less successful than promised, I’ve been at it for 1 hour and have only “reupholstered” 1 earphone… and it’s very partial (has holes). I rate my fixing result at 3/10, and I followed the instructions. :(
GYD - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 59
Afgelopen 30 dagen: 265
Altijd: 16,877
