Ga door naar hoofdinhoud
How to properly install the flex cable on the 4th Generation Touch
  1. How to properly install the flex cable on the 4th Generation Touch, How to properly install the flex cable on the 4th Generation Touch: stap 1, afbeelding 1 van 2 How to properly install the flex cable on the 4th Generation Touch, How to properly install the flex cable on the 4th Generation Touch: stap 1, afbeelding 2 van 2
    • Esta es la forma correcta de doblar el cable flex de la pantalla.
    • English: This is the correct way to bend the flex cable to the display.
  2. How to properly install the flex cable on the 4th Generation Touch: stap 2, afbeelding 1 van 1
    • No doblar el cable flex de esta forma.
    • English: Do not bend the flex cable this way.
  3. How to properly install the flex cable on the 4th Generation Touch: stap 3, afbeelding 1 van 1
    • Al doblar el cable flex de forma incorrecta la pantalla no entra completamente en el socket y se quiebra al tratar de cerrar el iPod.
    • English: Folding the flex cable incorrectly display no fully into the socket and breaks when trying to close the iPod.
Conclusie
12 andere personen hebben deze handleiding voltooid.
fibocellphone
569 Reputatie
1 Handleiding geschreven
Één opmerking
after replacing flex cable is not working so touch is not responding ,display is good ....how I can fix the touch.
Abhimanyu Raj - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 18
Altijd: 6,902
