Inleiding
Late 2008 MacBook Pros 15 inch models suffer from delamination of the top case which may occur on some models, as the unibody design of the screen isn't really unibody on these early models, but a glued two part item. Heat from computer that is blown onto the hinge slowly softens this glue and it can eventually cause it to separate. Apple had an out-of-warranty case that permitted free replacements of 15-inch Late 2008 MacBook Pro displays, but this case was valid until about 2013-2014.
Upon inspection of several these MacBook Pros 15-inch Late 2008 laptops, I discovered that some of them had very stiff hinges and display opened with too much force. Some of these already had some delamination of the display assembly. As the hinges get stiff, more force is applied on the display which over time causes the already weak glue that holds the outer display housing to break and separate from the back case.
To delay or even prevent the separation, the solution is to lubricate these hinges which is best done with the display removed, also recommended is to remove clutch cover. Only warning is, that sometimes then the hinges can become too soft and may not hold the display at the desired angle.
This guide is also valid for an A1278 Late 2008 MacBook Aluminium 13-inch model, but delamination and stiff hinges are very uncommon on these models (but it does still happen).
Wat je nodig hebt
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Grab the translucent plastic tab and pull the battery up and out of the Unibody.
If the latch is depressed it will lock the battery in place.
Remove the following eight screws securing the lower case to the chassis:
One 5.4 mm Phillips screw.
Three 14 mm Phillips screws.
Four 3.5 mm Phillips screws.
Disconnect the camera cable by pulling the male end straight away from its socket toward the optical drive opening.
Deroute the camera data cable from the channel in the optical drive.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display away from the upper case, minding any brackets or cables that may get caught.
Slide the clutch cover toward the right edge of the display.
Starting at its far left end, rock the clutch cover along its long axis while pulling it away from the clutch hinge.
Working from right to left, carefully continue to release and lift the clutch along the lower edge of the display assembly.
Lift the clutch cover up off the front bezel and set it aside.
Use a cloth or paper towel to cover the LCD and surroundings as you do not want to get any silicone lubricant there.
Spray small amount of silicone lubricant onto the display hinges, where the silver part is.
While you are there, check the three screws that hold the hinges for any play and re-tighten them if necessary.
4 andere personen hebben deze handleiding voltooid.
