Ga door naar hoofdinhoud
How to perform a Hard Reset on the Nintendo DS Lite
Wat je nodig hebt
  1. How to perform a Hard Reset on the Nintendo DS Lite, Battery: stap 1, afbeelding 1 van 1
    • Turn the DS to the back side.
  2. How to perform a Hard Reset on the Nintendo DS Lite: stap 2, afbeelding 1 van 2 How to perform a Hard Reset on the Nintendo DS Lite: stap 2, afbeelding 2 van 2
    • This is the PH00 Screw,
    • Unscrew it.
    • The screw remains captive to the battery cover, you do not need to worry about losing it.
  3. How to perform a Hard Reset on the Nintendo DS Lite, Removing the cover: stap 3, afbeelding 1 van 2 How to perform a Hard Reset on the Nintendo DS Lite, Removing the cover: stap 3, afbeelding 2 van 2
    • Remove the battery cover.
  4. How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: stap 4, afbeelding 1 van 3 How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: stap 4, afbeelding 2 van 3 How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: stap 4, afbeelding 3 van 3
    • Wedge the edge on the side of the battery using a spudger.
  5. How to perform a Hard Reset on the Nintendo DS Lite, .: stap 5, afbeelding 1 van 1
    • Take out the battery and leave it for at least 15-30 seconds.
  6. How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: stap 6, afbeelding 1 van 3 How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: stap 6, afbeelding 2 van 3 How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: stap 6, afbeelding 3 van 3
    • Reinsert the battery.
    • Make sure the battery matches the + and the - connectors.
  7. How to perform a Hard Reset on the Nintendo DS Lite, Screwing in the cover: stap 7, afbeelding 1 van 2 How to perform a Hard Reset on the Nintendo DS Lite, Screwing in the cover: stap 7, afbeelding 2 van 2
    • Put the cover back on and screw it in.
  8. How to perform a Hard Reset on the Nintendo DS Lite, Finish: stap 8, afbeelding 1 van 1
    • If everything done correctly, You should be at the setup screen, It would look like when you got the ds from the store.
    • You can hold A + B + X + Y + R while turning on the system and the ds will boot into a ds cartridge without doing setup, you can boot the Game Pak/GBA Cartridge if you hold A + B + X + Y + L Instead.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Artem Ivat
2.709 Reputatie
12 handleidingen geschreven
Kid fixers Lid van Kid fixers
Community
156 Leden
292 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 82
Afgelopen 30 dagen: 369
Altijd: 9,356
