Inleiding
Use this guide to open your Huawei Watch GT 2 (46 mm) for repairs.
Wat je nodig hebt
Before starting repairs, take your watch off the charger and power it down.
Remove the watch band.
Insert the edge of a spudger into the middle loudspeaker opening at the top edge of your watch.
Use the spudger to pry up the back cover assembly of your Huawei watch GT 2.
To reassemble your Huawei Watch GT 2 (46 mm), follow these instructions in reverse order.
Opening didn’t go as planned? Check out our Answers community for troubleshooting help.
11 andere personen hebben deze handleiding voltooid.
5 opmerkingen
How can i change the battery Watch GT2 (46mm)?
Thanks for the reply!
Hi Tamás,
the battery of the Huawei Watch GT2 is soldered to the bottom assembly cable. To replace it you're required to execute some very difficult micro soldering. The risk of damaging surrounding components is very high during that procedure.
hello, did you happened to replace only glass of smartwatch ?? is it posible ?? my oled and touch is working fine, but after glass unglued at corners somehow, my glass got broken. I have found that you can buy only glass for this watch.
My screen got water in and now the touch screen dont want to work.
Hi, i should replace only the touch panel avoid to replace completely the display. I did not find any information or any video.
Do you have any suggestion befere approach this task ? I have no idea about the glue i have to use in reassembly of the clock.
Thanks for you answer and job
