Ga door naar hoofdinhoud
How to open the Flipper Zero
Wat je nodig hebt
    • Go to Main Menu > Settings > Power.
    • Select Power OFF.
    • Alternatively, you can press and hold the Back-button for around 10 seconds.
    • Confirm by pressing the Right-button.
  1. How to open the Flipper Zero, Remove the microSD card: stap 2, afbeelding 1 van 1
    • Eject the microSD card by pressing it with your fingernail.
  2. How to open the Flipper Zero, Remove the screws: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Phillips #0 Screwdriver
    $5.49
    • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
    • Be careful, the screws are quite easy to strip.
  3. How to open the Flipper Zero, Open the back cover: stap 4, afbeelding 1 van 3 How to open the Flipper Zero, Open the back cover: stap 4, afbeelding 2 van 3 How to open the Flipper Zero, Open the back cover: stap 4, afbeelding 3 van 3
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
Conclusie
Sebastian
31.049 Reputatie
71 handleidingen geschreven
1Gids Commentaar
Amazing, this was super helpful, thank you for doing this amazing person!
Filiz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 38
Altijd: 3,122
