1. Locate the two grey latches on each side of the hood near the headlights. Pull the latches away from the hood to release the latches.
    • Locate the two grey latches on each side of the hood near the headlights.
    • Pull the latches away from the hood to release the latches.
  2. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  3. Reach underneath the hood and push up on the lever located in the front center of the hood.  You can now open the hood. Prop the hood open by inserting the hood support rod into the designated hole on the underside of the hood.
    • Reach underneath the hood and push up on the lever located in the front center of the hood. You can now open the hood.
    • Prop the hood open by inserting the hood support rod into the designated hole on the underside of the hood.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ryan Smith
227 Reputatie
1 Handleiding geschreven
Cal Poly, Team 7-51, Forte Fall 2012 Lid van Cal Poly, Team 7-51, Forte Fall 2012
CPSU-FORTE-F12S7G51
5 Leden
9 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 3
Afgelopen 7 Dagen: 46
Afgelopen 30 Dagen: 243
Altijd: 12,619
