Ga door naar hoofdinhoud
How to open and close a Metabo St EP 455
Wat je nodig hebt
  1. How to open and close a Metabo St EP 455, loosen the cover: stap 1, afbeelding 1 van 2 How to open and close a Metabo St EP 455, loosen the cover: stap 1, afbeelding 2 van 2
    • Make sure the jigsaw is unplugged.
    • Unscrew the bolt holding the guide plate to the jigsaw.
    • Unscrew the 10 screws holding the 2 frame halves together.
  2. How to open and close a Metabo St EP 455, separate the 2 halves: stap 2, afbeelding 1 van 2 How to open and close a Metabo St EP 455, separate the 2 halves: stap 2, afbeelding 2 van 2
    • Separate the 2 halves by slowly prying them apart, going around the edges evenly.
    • When separated, take care of some loose parts.
    • The nut holding the guide plate bolt.
    • Piece of plastic holding some cables.
    • Metal strip pushing the blade back.
  3. How to open and close a Metabo St EP 455, prepare to put the halves together: stap 3, afbeelding 1 van 2 How to open and close a Metabo St EP 455, prepare to put the halves together: stap 3, afbeelding 2 van 2
    • Regardless of how the halves are separated, to put them back together, it is practical to put the saw blade mechanism in the halve with the rest of the parts.
    • Then, make sure the right parts line up and are fitted correctly:
    • The holes for the blade holder. The axis is located on the other halve.
    • The blade driver.
    • The blade guide.
    • The metal strip.
  4. How to open and close a Metabo St EP 455, close it: stap 4, afbeelding 1 van 1
    • Now, add the empty halve on top of the halve containing the parts.
    • Screw everything back together.
Eindstreep
knipwim
8.685 Reputatie
31 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 39
Altijd: 1,558
