Ga door naar hoofdinhoud
Fix Your Stuff
Right to Repair
Parts & Tools
Inleiding
This guide will walk you through how to change the paper and common problems and solutions associated with being low on paper.
  1. Open the paper tray to see if it is empty.
    • Open the paper tray to see if it is empty.
  2. If the paper tray is empty, add paper to the tray.
    • If the paper tray is empty, add paper to the tray.
    • If there is already paper in the tray, realign the paper so that it fits in the gears, and can feed through properly.
  3. Ensure that all paper is in the correct tray.
    • Ensure that all paper is in the correct tray.
    • The correct tray is on the upper deck of the printer.
  4. Run the printer to verify it now prints.
    • Run the printer to verify it now prints.
    • If the paper still does not run through the printer, inspect the paper tray again.
  5. Remove any paper that looks to be overloading the tray feeder.
    • Remove any paper that looks to be overloading the tray feeder.
    • Sometimes there can be too much paper in the tray, preventing it from working properly.
  6. Try to print one last time. If it still fails, consider consulting a page to update drivers.
    • Try to print one last time. If it still fails, consider consulting a page to update drivers.
Conclusie
Joe
1 Reputatie
4 handleidingen geschreven
James Madison, Team 2-5, Allen Fall 2011 Lid van James Madison, Team 2-5, Allen Fall 2011
JMU-ALLEN-F11S2G5
1 Lid
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 854
