Inleiding
This guide replaces the LaserJet 1012 Vista driver installation guide.
If you have a Legacy HP LaserJet HP no longer supports and does not provide drivers for or you want a single driver that works for your fleet, this guide will show you how to install and use the HP UPD on your Windows system.
Note: Some printers may have problems with their respective utilities using this driver. This most commonly affects older models like the P2015, P2035, P2055 and M401 series.
HP typically ships the UPD with newer printers, but may customize the driver if the utilities are printer specific. As such, utility availability cannot be guaranteed.
Find out what print languages your printer supports. This printer (LaserJetPro 400 M401n) supports PCL6, PCL5 and PostScript. PCL6 is recommended for this printer.
If you use USB, plug your printer in now.
Once you know what print languages your printer supports, download the best one for your printer. The driver can be found on the HP website.
At the installation screen, select USB mode- Plug and Play.
Once you select the mode, pick the options you wish to use. While these settings can be changed, they should be left alone unless you understand what you're doing.
Click Next and the files will be copied to your computer.
After the driver loads, agree to the license agreement.
Once you agree to the license agreement, you will be asked which installation mode you want to use. At this point, select Dynamic Mode and click Next.
After selecting Dynamic Mode, click Next. The printer driver will be installed, along with a universal printer.
Once the driver is installed, additional configuration is required. All printers you wish to use will need to be configured over IP in Devices and Printers, which needs to be done manually.
Find Devices and Printers. The location varies based on which version of Windows you run, but this can be found in Control panel. Windows 8.x: Search for "Devices and Printers"; Windows 10: Search for Control panel and find Devices and Printers.
Click Add a Printer. If you use a USB cable, select Add a Local printer. For network installation, select Add a Network, Wireless or Bluetooth printer.
Allow your computer to populate the driver list. Find HP and then locate the driver that says HP Universal Printing PCL6 [Version]. Select this driver and click Next.
Name your printer. Once a name is selected, click Next.
After the printer is installed, print a test page to make sure it works. To do this, click Print a test page.
Één andere persoon heeft deze handleiding voltooid.
Één commentaar
I bought an HP printer specified by laserjet. I have followed a few steps to install this printer via HP UPD. at first search for the correct driver, then install it first in a USB mode after that in dynamic mode. then set the configuration pf printer and after completing all the steps just print once for a test.
www.facebook.com
