Inleiding
Use this method to force restart your OnePlus Nord in case it hung up, got stuck in menus, or froze.
Simultaneously push and hold the volume up and the power button.
Release both buttons when you see the OnePlus logo come up.
19 andere personen hebben deze handleiding voltooid.
9 opmerkingen
what is this weird problem one plus nord suddenly get switch off while on call ..
kindly advice to get ride of this problem for forever .
My mobile has hanging & automatically switch off/on please solve problem
It worked! Great help! Thank youuu
Finally after trying for over 2 hours! Than you so much!
mi telefono aparese que est corrupt i lo e reiniciado pero no enciende nomas cae eso
Ok now mine is stuck on the start and recovery menu but I can't select start bc my power button doesn't work
Thank you so much for this.
my 1 plus nord touch screen not working...i already have restart it many times with press power and long press volume ..now neither its swiching off nor working...please help me to atleast switching it off
Finally - THAT worked!! Thanks. Other fixes from other sites tell you to press the “power off button”. Duh! Screen not responsive! Kudos for your research and answers.
freerealm - Antwoord
As you suggested i did it . Finally i got my mobile started.
Epic Hemang - Antwoord
I find charging port is too loose and does not connect with charging cord.. Battery charge runs out. What should I do?
amicuscurious - Antwoord
Most of the time its because there is dust in the charging port that causes that. Gently try to clean that and it should be good as new.
Sparky -
