Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
How to fix water leaking from the side of the capsules
Wat je nodig hebt
  1. How to fix water leaking from the side of the capsules, Where does the water come from ?: stap 1, afbeelding 1 van 1
    • There is no reason to take the machine apart if the leak is not from the inside.
    • If the water runs down the cup bay (starting from where the red arrows are) it indicate a plate failure.
    • You will most likely also see a puddle of water at the base of your machine.[br]This comes from the water running backwards from the plate and into the machine.
    • You should try to clean or replace the plate first, before opening the machine.
  2. How to fix water leaking from the side of the capsules, Examine, clean or replace the Capsule Piercing Plate and enjoy: stap 2, afbeelding 1 van 3 How to fix water leaking from the side of the capsules, Examine, clean or replace the Capsule Piercing Plate and enjoy: stap 2, afbeelding 2 van 3 How to fix water leaking from the side of the capsules, Examine, clean or replace the Capsule Piercing Plate and enjoy: stap 2, afbeelding 3 van 3
    • Disconnect the device from the mains voltage. You will also appreciate to remove the water container.
    • Remove the capsule holder.
    • Close the lid (as if you were to make a brew)
    • Insert the small screwdriver at the point shown by the red arrow, press the screwdriver inwards 2->3 mm and the plate should drop down. There is a small spring behind which is moved. The spring sits on the plate. Due to lots of calcium deposits the plate may need a little help to come down.
    • Insert the new or cleaned plate, latch backend first and click in place in the front.
    • Once done, connect the device and make your self a brew and see if it is well-deserved. No Leaks - You've earned it. Leaks = You need that cup to ponder where the issue then is :-)
Conclusie
Once done, connect the device again and make your self a brew to see if it is well-deserved.
Search for other guides in this forum. Search for "Dolce Gusto leaking water".
12 andere personen hebben deze handleiding voltooid.
Jan Carsten Jorgensen
1.028 Reputatie
6 handleidingen geschreven
8 opmerkingen
Hi there.
I have followed this and my plated was very scaled so cleaned an d put back but it still leaks. Same place. Any ideas?
I have a fontana but they all seem to have the same plate. Thanks
laura.hill925 - Antwoord
thanks for this easy to follow guide, ive finally fixed that pesky leak!
Gladys Beckett - Antwoord
Took place out but can't put it back because the plate above it won't go back. Can't close the lid to replace it.
Francis - Antwoord
i was Stupid enough to buy the Nescafe Dolce Gusto and it started leaking so I replaced the piercing plate and I bet it hadnt even made more than 30 - 40 coffee’s the new plate has done about the same and started leaking again,
My advice is dont buy one of these machines unless you only want it as an ornament they are Crap and I wouldnt rate them as being worth anymore than about £5 tops.
bcf.gibson22 - Antwoord
Thank you so much! Your guide fixed the leak!
The leak happened shortly after I descaled the machine. There was a tiny sand-like grain, stucked inside the needle, probably blocking most of the flow.
Thank you!
bobi_nguen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 65
Afgelopen 7 dagen: 494
Afgelopen 30 dagen: 2,289
Altijd: 81,681
