Ga door naar hoofdinhoud
How to Fix Jammed Nintendo Switch ZR and ZL buttons
Wat je nodig hebt
  1. How to Fix Jammed Nintendo Switch ZR and ZL buttons, Unscrew the back cover: stap 1, afbeelding 1 van 1
    • Using the Y00 Tri-Point screwdriver, remove four M1.4 x 5mm screws to loosen the hard plastic back of the Joy-Con.
    • After the screws are removed, lift the cover to reveal the inside of the Joy-Con and locate the ZL button.
    • The button exposed could either be the ZL or the ZR depending on which Joy-Con needs to be fixed.
    • Use tweezers to lift the ZL button a little then pull upwards to get it back into place.
    • Once the button is back in place, place the hard cover back on the Joy-Con and screw it back on.
    • Click the button a couple times to ensure that it's back in place and working.
    • This may either be the ZL or ZR button depending on the Joy-Con being fixed.
  2. How to Fix Jammed Nintendo Switch ZR and ZL buttons: stap 5, afbeelding 1 van 1
    • Resume gameplay!
Conclusie
After following those 7 steps, your gameplay should return to its original state. If the other Joy-Con also has a jammed ZL or ZR button simply repeat the 7 steps above.
12 andere personen hebben deze handleiding voltooid.
Gabriela Cruz-Pagan
435 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 56
Afgelopen 7 dagen: 370
Afgelopen 30 dagen: 1,684
Altijd: 91,253
