Ga door naar hoofdinhoud
How to fix iPhone 6S/6S+ home button, when home button click does not work.
Wat je nodig hebt
  1. How to fix iPhone 6S/6S+ home button, when home button click does not work., Home Button Assembly: stap 1, afbeelding 1 van 1
    • Remove the two 1.9 mm Phillips screws securing the home button bracket.
    Maybe this should be totally obvious, but it took me a minute or two to realize that this step is performed on the DISPLAY ASSEMBLY that was just removed, rather than the main body of the phone, which is the part on which all the previous steps were performed.
    Tom - Antwoord
    The new display came with a 1.9mm screw installed (the top left one above). This must be removed before putting back the home button bracket. It took me way too long to realize why I couldn’t thread the old screw back into the hole.
    Brandon Mathew - Antwoord
    If you bought a screen assembly with a home button but have not ever set up touch ID can you set up touch ID on the new screen’s home button?
    Andrew Shircel - Antwoord
    The home button and logic board are usually married. So if it’s a new home button paired with the original logic board, the Touch ID won’t work.
    Brittni Gange -
    do not over tight the screw or the lcd will get damaged
    764349 - Antwoord
  2. How to fix iPhone 6S/6S+ home button, when home button click does not work.: stap 2, afbeelding 1 van 2 How to fix iPhone 6S/6S+ home button, when home button click does not work.: stap 2, afbeelding 2 van 2
    • Remove the home button bracket.
    My home is wiggley I do not like it
    can you put home button adhesive
    Riley - Antwoord
  3. How to fix iPhone 6S/6S+ home button, when home button click does not work.: stap 3, afbeelding 1 van 2 How to fix iPhone 6S/6S+ home button, when home button click does not work.: stap 3, afbeelding 2 van 2
    • Use the pointed tip of a spudger to disconnect the home button cable from its connector on the display assembly.
    Gently: this piece is attached to the plastic cabling, not the surface of the phone
    Christa - Antwoord
    Buongiorno,ho cambiato display però adesso non mi funziona touch sul tasto home…cosa potrebbe essere???grazie
    eduartkurani - Antwoord
    ciao, hai risolto? ho sto valutando se cambiare lo schermo appunto per questo motivo, ho letto online che gli schermi non originali danno questo problema
    serena184 -
  4. How to fix iPhone 6S/6S+ home button, when home button click does not work.: stap 4, afbeelding 1 van 2 How to fix iPhone 6S/6S+ home button, when home button click does not work.: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    iOpener
    $19.99
    Koop
    • The rubber gasket surrounding the home button is very thin and tears easily.
    • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
    • Using your fingertip, gently press up on the home button from the front side of the display assembly. Use firm, constant pressure to slowly separate the home button's rubber gasket from the front panel.
    “The gasket is very thin and will tear easily. Apply steady pressure and give it time to separate. “
    The note above was very helpful. It really is thin and for one second I thought I punctured a whole through it, so be careful.
    Jeffrey Robinos - Antwoord
    I did this on 2 separate phones. The first time, I did it according to directions, and it worked well. However, the adhesive pulled off in the process. On the 2nd phone I used a handwarmer to slightly warm the home button area. (I think an iOpener would work best, but I didn’t have one on hand). With the constant pressure after being heated, the home button assembly came off easily, and the adhesive stayed in place. I’ll definitely use slight heat in the future for this step as it seems to lessen the possibility of damaging the assembly.
    Jami - Antwoord
    I would have liked to see the heating instructions on this page. I only saw it once I re-watched the video as I was having trouble getting the button out. iFixit would have made another sale had it been obvious that the heating pad would come in handy. I ended up using a microwave heating pad instead. Worked fine.
    Scott - Antwoord
    If anyone else is totally caught off guard by the need for heat at this point, the previous mention of a heating pad gave me the idea of heating a wet paper towel in the microwave and sticking it in a plastic bag. Obviously make sure no moisture escapes into the device. Worked fine, and is absolutely necessary: that gasket is VERY delicate.
    Joshua Rodgers - Antwoord
  5. How to fix iPhone 6S/6S+ home button, when home button click does not work.: stap 5, afbeelding 1 van 3 How to fix iPhone 6S/6S+ home button, when home button click does not work.: stap 5, afbeelding 2 van 3 How to fix iPhone 6S/6S+ home button, when home button click does not work.: stap 5, afbeelding 3 van 3
    • Use the pointed end of a spudger to pry the lightly-adhered home button flex cable off the display assembly.
  6. How to fix iPhone 6S/6S+ home button, when home button click does not work.: stap 6, afbeelding 1 van 2 How to fix iPhone 6S/6S+ home button, when home button click does not work.: stap 6, afbeelding 2 van 2
    • Remove the home button assembly.
    Make sure you remove any broken glass from around the button edges. Took me a few times to realize it had some glass on it.
    johnarchitzel - Antwoord
    I could not believe how EASY this was to repair my phone! Granted, it took me awhile (2 hrs) to replace a camera and a screen, but I was probably overly meticulous about each step, especially making sure the old adhesive was fully removed and the frame was clean. I can imagine, with tolerances being as tight as they are — I could barely see some of the screws! — the slightest lump of glue might have made a smooth placement difficult. But, in the end, it was worth it! Screen looks and works awesome, and so does my camera!
    Huge props to you for this detailed guide! Very easy to follow and flawless result! Thank you!
    Patrick Lynch - Antwoord
    does the home button work after you put it on the new repaired phone?
    Victoria Vojvodich - Antwoord
    what about the camera? i don’t see the step moving the old camera over to the new screen
    Brian - Antwoord
    Gasket guys!! How do you properly replace the gasket?? Not shown!!
    Jim Hickman - Antwoord
    Friends, take a very, very close look at how the connector on the replacement screen is situated. It rests BEHIND a small L shaped ledge that holds it in place. Once connected to the home button ribbon, you will need to seat it behind the little ledge. Otherwise it will be sitting on top of the ledge, and the metal cover won't fit properly before it is screwed back in place.
    Richard Perl - Antwoord
  7. How to fix iPhone 6S/6S+ home button, when home button click does not work., Finding the Cause: stap 7, afbeelding 1 van 3 How to fix iPhone 6S/6S+ home button, when home button click does not work., Finding the Cause: stap 7, afbeelding 2 van 3 How to fix iPhone 6S/6S+ home button, when home button click does not work., Finding the Cause: stap 7, afbeelding 3 van 3
    • Though this step isn't necessary, here are some images to help you see the cause of the issue
    • Here you can see the micro-tear that happens just under the edge of the home button.
  8. How to fix iPhone 6S/6S+ home button, when home button click does not work., Locating the Component: stap 8, afbeelding 1 van 3 How to fix iPhone 6S/6S+ home button, when home button click does not work., Locating the Component: stap 8, afbeelding 2 van 3 How to fix iPhone 6S/6S+ home button, when home button click does not work., Locating the Component: stap 8, afbeelding 3 van 3
    • Find the resistor tied to the home button and remove the protective layer around that resistor.
  9. How to fix iPhone 6S/6S+ home button, when home button click does not work., Verify the Issue: stap 9, afbeelding 1 van 1
    • Test continuity between top part of the resistor and the home button.
    • If you get constant continuity between these two points, you have another issue and this process will not fix your issue.
  10. How to fix iPhone 6S/6S+ home button, when home button click does not work., Soldering (Part 1): stap 10, afbeelding 1 van 1
    • Now that you have confirmed the issue, you can fix it by running an external trace between the two components you just tested.
    • Solder your wire to the physical part of the home button first.
  11. How to fix iPhone 6S/6S+ home button, when home button click does not work., Soldering (Part 2): stap 11, afbeelding 1 van 3 How to fix iPhone 6S/6S+ home button, when home button click does not work., Soldering (Part 2): stap 11, afbeelding 2 van 3 How to fix iPhone 6S/6S+ home button, when home button click does not work., Soldering (Part 2): stap 11, afbeelding 3 van 3
    • Guide the wire to the second component
    • It is easier to keep the wire in place if you cut part of the glue out in a line. That way you can insert the wire into the cutout to prevent it from moving
    • Add some glue or UV resin to keep the wire in place.
    • Solder the wire to the top end of the component.
  12. How to fix iPhone 6S/6S+ home button, when home button click does not work., Glue and Assemble: stap 12, afbeelding 1 van 1
    • Add some UV Curing Glue to the solder points.
    • To be safe, you can place some Kapton tape over the top of the new trace to keep it from moving. Be careful as this new trace is fragile where it isn't glued.
    • Follow steps 1-6 in reverse order to re-assemble the device.
Conclusie
After testing the home button and confirming that the repair worked, you can re-assemble your device.
11 andere personen hebben deze handleiding voltooid.
Jon
633 Reputatie
1 Handleiding geschreven
4 opmerkingen
Superb it worked
kumkrish36 - Antwoord
Looks like have to attempt this. Have done fairly fine soldering before but maybe nothing this small. What size jumper to use? 0.1mm or 0.02mm?
Howard - Antwoord
Thanks Howard. Sorry I haven’t been around for a while. The wire I used was 0.02 mm. You would probably be fine with a thicker wire, this is just what I have on hand.
Jon -
Great tutorial. There is a diagram floating around on the web that has the polarity reversed. I did that first and didn’t work before finding this guide and corrected the wiring. Works great now.
Besides a good fine tip soldering iron and at least magnifying goggles, really good flux makes all the difference on this job since everything is so small. I had some clear liquidy flux (Kester 951? don’t recall, bought long ago to help reflow GPU+SOC BGAs) That worked great as heat instantly flowed to all the right places. Necessary with tiny solder points and rework wire.
Howard - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 59
Afgelopen 30 dagen: 198
Altijd: 10,098
