Ga door naar hoofdinhoud
How to fix a stuck Sony Cyber-shot DSC-P10 lens cover
Wat je nodig hebt
  1. How to fix a stuck Sony Cyber-shot DSC-P10 lens cover, How to fix a stuck Sony Cyber-shot DSC-P10 lens cover: stap 1, afbeelding 1 van 1
    • Pull back the lens shutters manually if necessary.
    • NOTE: A can of compressed air can be found in almost any store
  2. How to fix a stuck Sony Cyber-shot DSC-P10 lens cover: stap 2, afbeelding 1 van 2 How to fix a stuck Sony Cyber-shot DSC-P10 lens cover: stap 2, afbeelding 2 van 2
    • Blow the area inside the flaps and around them with the can of compressed air.
    • If the flaps don't immediately work, continue to attempt to blow the debris out while periodically checking to see if the problem is fixed
Conclusie
After following this guide, the lens flaps should open and close freely as necessary.
Één andere persoon heeft deze handleiding voltooid.
Renee
125 Reputatie
1 Handleiding geschreven
UW Stout, Team 1-1, Zhou Fall 2011 Lid van UW Stout, Team 1-1, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G1
5 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 45
Altijd: 4,841
