Ga door naar hoofdinhoud
How to fix a ripped back pocket of jeans
Wat je nodig hebt
  1. How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: stap 1, afbeelding 1 van 3 How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: stap 1, afbeelding 2 van 3 How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: stap 1, afbeelding 3 van 3
    • Pin down the ripped portion of the jeans back pocket.
    • Use as many pins as needed to ensure the pocket does not slip from the correct place while sewing.
  2. How to fix a ripped back pocket of jeans: stap 2, afbeelding 1 van 2 How to fix a ripped back pocket of jeans: stap 2, afbeelding 2 van 2
    • Thread the needle with the polyester thread.
    • Use about an arms length of thread to ensure that you have enough to sew with.
  3. How to fix a ripped back pocket of jeans: stap 3, afbeelding 1 van 1
    • Cut the ends of the thread.
  4. How to fix a ripped back pocket of jeans: stap 4, afbeelding 1 van 2 How to fix a ripped back pocket of jeans: stap 4, afbeelding 2 van 2
    • Tie a double knot at the end of the two threads.
  5. How to fix a ripped back pocket of jeans: stap 5, afbeelding 1 van 2 How to fix a ripped back pocket of jeans: stap 5, afbeelding 2 van 2
    • Start to sew from the bottom of the pocket up.
  6. How to fix a ripped back pocket of jeans: stap 6, afbeelding 1 van 2 How to fix a ripped back pocket of jeans: stap 6, afbeelding 2 van 2
    • Remove pins as the needle and thread approaches the pins.
  7. How to fix a ripped back pocket of jeans: stap 7, afbeelding 1 van 3 How to fix a ripped back pocket of jeans: stap 7, afbeelding 2 van 3 How to fix a ripped back pocket of jeans: stap 7, afbeelding 3 van 3
    • Loop the needle through the thread to tie a knot to end and secure the sewing.
  8. How to fix a ripped back pocket of jeans: stap 8, afbeelding 1 van 1
    • Cut the loose threads to clean up the sewing.
Conclusie
Ashley Dembroski
157 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G2, Cardinal Summer 2020 Lid van UW Tacoma, Team S1-G2, Cardinal Summer 2020
UWT-CARDINAL-SU20S1G2
1 Lid
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 37
Altijd: 4,091
