Ga door naar hoofdinhoud
How to fix a rattling window, E46 M3
Wat je nodig hebt
Video overzicht
  1. How to fix a rattling window, E46 M3, Identify the screws: stap 1, afbeelding 1 van 1
    • The door card is held securely in place with 5 screws.
    • Keep in mind the door card has up to 3 wire bundles attached to it. Be careful when removing it! Be prepared to support it while dealing with the wires.
    Vraag FixBot
    Voeg opmerking toe
  2. How to fix a rattling window, E46 M3, Remove screw covers: stap 2, afbeelding 1 van 2 How to fix a rattling window, E46 M3, Remove screw covers: stap 2, afbeelding 2 van 2
    • Using a spudger, work off the cap of the first screw. The cap is tight; you may need a jimmy or metal spudger.
    • Using the flat end of a spudger, remove the airbag emblem. The emblem has clips on the top and bottom -- work carefully.
    Vraag FixBot
    Voeg opmerking toe
  3. How to fix a rattling window, E46 M3, Remove bolts: stap 3, afbeelding 1 van 1
    • Using a T20 Torx driver with extension, remove all 5 bolts.
    Vraag FixBot
    Voeg opmerking toe
  4. How to fix a rattling window, E46 M3, Remove mirror control: stap 4, afbeelding 1 van 1
    • If you're working on the driver side door, remove the mirror control module. Disconnect it from its wiring plug.
    Vraag FixBot
    Voeg opmerking toe
  5. How to fix a rattling window, E46 M3, Pop door card clips: stap 5, afbeelding 1 van 2 How to fix a rattling window, E46 M3, Pop door card clips: stap 5, afbeelding 2 van 2
    • Using a trim tool or similar, begin at the bottom of the door card and pop the card away from the door frame.
    • After you've released the bottom clips, work your way around.
    • You will need to lift the door card from the door frame in order to fully release it. Be careful!
    Vraag FixBot
    Voeg opmerking toe
    • Disconnect the following from the door panel:
    • Unlocking cable
    • Speaker cable(s)
    • Set the door panel aside.
    Vraag FixBot
    Voeg opmerking toe
  6. How to fix a rattling window, E46 M3, Door panel removed!: stap 7, afbeelding 1 van 1
    • The door panel is now removed.
    • You will see the airbag module, vapor barrier, and other components.
    Vraag FixBot
    Voeg opmerking toe
  7. How to fix a rattling window, E46 M3, Inspect the post: stap 8, afbeelding 1 van 2 How to fix a rattling window, E46 M3, Inspect the post: stap 8, afbeelding 2 van 2
    • Very gently, peel back the vapor barrier to expose the retaining bolt.
    • Roll the window up.
    • The tar-like substance used to seal the vapor barrier to the door frame WILL release itself to a gentle pull, but it is EXTREMELY sticky, and too much pulling will tear your barrier. Slow and steady is the name of the game!
    • Inspect the bolt. It is probably missing a nut!
    Vraag FixBot
    Voeg opmerking toe
  8. How to fix a rattling window, E46 M3, Inspect the other bolt: stap 9, afbeelding 1 van 1
    • While you're in here, inspect and tighten the bottom bolt.
    Vraag FixBot
    Voeg opmerking toe
  9. How to fix a rattling window, E46 M3, Find and replace!: stap 10, afbeelding 1 van 1
    • Look in the bottom of your door and locate the nut that fell off that top bolt.
    • Replace the nut onto the upper bolt and tighten.
    • In a pinch, you can use a little bit of that tarry substance to temporarily paste the nut to your fingertip in order to screw it on to the bolt.
    Vraag FixBot
    Voeg opmerking toe
    • Ta da! Now closing the door sounds great!
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your door, follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Dom Santangelo
655 Reputatie
3 handleidingen geschreven
1Gids Commentaar
What is this bullshit? Ever think people may have both bolts there and tightened down still? Ever think other ifixit $@$* may still need to occur? And this is all you have to offer? Awesome thoroughness…
spamaccount420 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 53
Altijd: 10,194
