Ga door naar hoofdinhoud
How to fix a blown heater element in a Toaster
Wat je nodig hebt
Video overzicht
    • Insert wisdom here.
    • how to fix a toaster
Conclusie
Not too difficult, you need patience though.
5 andere personen hebben deze handleiding voltooid.
jon
3.210 Reputatie
22 handleidingen geschreven
2Gids Commentaar
this solution worked great for a bout a two weeks, then despite having connectivity in the ribbon, it does not heat up. It sounded like you weren’t expecting your solution to work forever. Did it give out on you after a little bit because of the increased resistance and the crimp?
mitchell.drury - Antwoord
Mine is still working even after all this time (over 2 years ago). If your heater element is still connected (low resistance) then the fault is somewhere else. Trace the resistance of connections back through the switch to the plug to find the fault.
jon - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 73
Altijd: 26,793
