Ga door naar hoofdinhoud
How to fix a Backpack with a Broken Mesh
Wat je nodig hebt
  1. How to fix a Backpack with a Broken Mesh, Identify the repair area: stap 1, afbeelding 1 van 3 How to fix a Backpack with a Broken Mesh, Identify the repair area: stap 1, afbeelding 2 van 3 How to fix a Backpack with a Broken Mesh, Identify the repair area: stap 1, afbeelding 3 van 3
    • Identify the defective area and assess how large the damage is.
  2. How to fix a Backpack with a Broken Mesh, Cut the mesh: stap 2, afbeelding 1 van 3 How to fix a Backpack with a Broken Mesh, Cut the mesh: stap 2, afbeelding 2 van 3 How to fix a Backpack with a Broken Mesh, Cut the mesh: stap 2, afbeelding 3 van 3
    • Use a pair of scissors to cut the mesh.
    • Make sure you start cutting at the edge of the seam.
    • The cut should be "clean", without leaving any mesh parts behind.
  3. How to fix a Backpack with a Broken Mesh, Clean the area: stap 3, afbeelding 1 van 2 How to fix a Backpack with a Broken Mesh, Clean the area: stap 3, afbeelding 2 van 2
    • Removed the mesh completely and set aside.
  4. How to fix a Backpack with a Broken Mesh, Finished and ready!: stap 4, afbeelding 1 van 3 How to fix a Backpack with a Broken Mesh, Finished and ready!: stap 4, afbeelding 2 van 3 How to fix a Backpack with a Broken Mesh, Finished and ready!: stap 4, afbeelding 3 van 3
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusie
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
10.230 Reputatie
66 handleidingen geschreven
INTERSPORT Lid van INTERSPORT
Community
25 Leden
169 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 35
Altijd: 535
