Ga door naar hoofdinhoud
How to fix TC Electronic Level Pilot static noise
Wat je nodig hebt
  1. How to fix TC Electronic Level Pilot static noise, How to fix TC Electronic Level Pilot static noise: stap 1, afbeelding 1 van 1
    • The bottom rubber base can be removed
  2. How to fix TC Electronic Level Pilot static noise: stap 2, afbeelding 1 van 1
    • Spray the small opening there with some multi-purpose oil.
Conclusie
11 andere personen hebben deze handleiding voltooid.
Alpha Dimension
388 Reputatie
1 Handleiding geschreven
6 opmerkingen
Not a good idea. Oil will &&^& it up dah.
stevenowlbassett - Antwoord
DeOxit (contact cleaner designed specifically for potentiometers) is what most people are recommending, not WD40 or dielectric grease..
Preferably DeOxit Gold, or at least not their (Hosa's) Fader Lube.
mystiphysician - Antwoord
Yes, use DeOxit or some similar contact cleaner
Eng Wei Chua - Antwoord
That knob became scratchy after some use. Cramolin contaclean helped, as always. Thanks for the teardown guide.
Daniel Leonov - Antwoord
Thanks Alpha Dimension for your disassembly guide.
If one needs to change it, it’s a Bourns potentiometer and its complete reference is PTD904-1020K-A103 (I’ve checked with measures on the potentiometer of my Level Pilot and with the PDF reference here : https://www.bourns.com/docs/product-data...)
Hervé HERRY - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 22
Altijd: 5,655
