Ga door naar hoofdinhoud
How to fix Logitech Anywhere MX Phantom Double Click
Wat je nodig hebt
  1. How to fix Logitech Anywhere MX Phantom Double Click, Front Screw Removal: stap 1, afbeelding 1 van 1
    • The front screws are underneath the front gliders. The can be removed with a butterknive or Plastic Opening Tool. The gliders have three layers, be careful not to seperate them.
  2. How to fix Logitech Anywhere MX Phantom Double Click, Removing Back Screws: stap 2, afbeelding 1 van 1
    • The back screws are underneath the stickers with the battery images. You can either remove them, like I did, or just poke a hole into them to get to the screws.
  3. How to fix Logitech Anywhere MX Phantom Double Click, Identification of the Problem: stap 3, afbeelding 1 van 1
    • After the four screws are removed, the top and the bottom part can be easily taken apart. In the top part the grove that was made by the click-sensor should be cleary visible. This causes the phantom double clicks.
  4. How to fix Logitech Anywhere MX Phantom Double Click, Solution of the Problem: stap 4, afbeelding 1 van 1
    • Put a piece of tape over the groove.
Conclusie
63 andere personen hebben deze handleiding voltooid.
Stefan Magometschnigg
1.957 Reputatie
2 handleidingen geschreven
43Gids Commentaar
Worked well for me, lets see how long it'll last.
Wynadorn - Antwoord
Worked for me too...saved a great little mouse!
jcrhino - Antwoord
Thank you for this hint! It worked perfectly
Wojciech Gradkowski - Antwoord
Thank you, it worked!
Jakab Ponoczky - Antwoord
Thank you for this guide! Got my mouse working and saved me some money :)
Kon-Kon Chao - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 40
Afgelopen 30 dagen: 294
Altijd: 50,550
