Inleiding
This guide will show how to fix squeaking on the Free Wheelchair Mission GEN 2 Wheelchair.
Squeaking of the wheelchair may be caused by different problems, being dirt, improper assembly, or not enough lubrication. In step two of this guide, reference to the tear down of the wheelchair is needed which can be found here. Tools that are needed to fix improper assembly or to remove parts for a deeper clean are also listed at the top of the teardown page. Bike grease may be needed for proper lubrication in step two as well.
It is best to have an open and clean area for this repair for easy accessibility to the wheelchair.
Wat je nodig hebt
Locate the source of the squeaking.
Clean and remove any dirt or rust from the source of the squeaking.
Squeaking can be caused by overly tightened connections. If problem still occurs after going through steps, try to slightly loosen bolts (half a turn of the wrench) near the source of squeaking.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
A quick spray of Extralube C60 Trigger Spray will keep the components rust free and spinning for much longer... worth a go www.team-zx1.com
