Inleiding
Does your 1.9 TDI suddently sets out or fail to start and there are no events in the log ?
The engine suddently cut off very shortly (less than a second) while driving, mostly while maintaining level speed
You may be fast to observe the glow plug indicator lights up very briefly when the engine cuts off
The car may refuse to start when warm, not overheated, and then willingly start when cold again
You may hear a crackling sound when the temperature is below freezing and the glow-plugs has to be active for longer than usual
It can happen once or many times during a days driving - OR it happens only once a month - No schedule or pattern.
In my 1998 SEAT Toledo 1.9 TDI (90 HP) the relay with label 109 on the top was the culprit
Access the relay where the fuses are located. in my car it was in the drivers side behind the small glove compartment.
Talk about loose connections...See inside the red box of photo 1
Secondly, the strip inside the relay barely touches the terminal. See photo 2
These two loose connections account for the erratic behaviour of the engine
The relay is worn out.....the copper-wire is yellowish to look at, compared to the more known copper-colored - replace the relay. Photo 3 does not clearly show it, but may get an idea
Buy a new relay, as used ones may be similar worn. Replace the relay and reassemble the lid to the fusebox
