Ga door naar hoofdinhoud
How to determine Mac shutdown causes
  1. How to determine Mac shutdown causes, Open Terminal.app: stap 1, afbeelding 1 van 1
    • Open Terminal.app
  2. How to determine Mac shutdown causes, Listing previous shutdowns: stap 2, afbeelding 1 van 1
    • Copy and paste the following command in your Terminal window:
    • log show --predicate 'eventMessage contains "Previous shutdown cause"' --last 24h
    • The "24h" portion of the command can be changed to any number of hours, depending on how far back you need to see.
  3. How to determine Mac shutdown causes, Determining Shutdown Causes: stap 3, afbeelding 1 van 1
    • The previous shutdown causes in the timeframe you selected will appear as a list.
    • Common shutdown causes include 5 which indicates a normal shutdown, 3 which indicates a hard shutdown (i.e. holding the power button), and 0 which indicates the power was disconnected.
    • A list of shutdown causes can be found here: Shutdown causes (from George Garside blog)
Conclusie
Done! You should be able to use these codes to further troubleshoot random shutdowns or other strange events.
Hit the button below if this guide helped solve your issue :)
24 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
Jonah Aragon
5.699 Reputatie
5 handleidingen geschreven
Experimax Coon Rapids Lid van Experimax Coon Rapids
Business
3 Leden
19 handleidingen geschreven
14Gids Commentaar
For me it says
kernel: (AppleSMC) Previous shutdown cause: -20
The attached PDF (and the internet) doesn’t seem to have any information about this code. What’s the source of the codes for the PDF? Maybe they have updated listing for shutdown codes.
Saurabh Shrivastava - Antwoord
we also have -20 as a cause and have no idea what it means. did you ever find it out?
octomobiki -
I also have -20 code of shut down after macOS 10.15.5 update with MBP 16inches model.
but no information at all….
赤月小黄泉 -
writErr = -20, /*I/O System Errors*/ its this error for code -20 .. Find all error codes here :- https://krypted.com/lists/comprehensive-...
UNKNOWN X -
Sorry , that was not related, check this one : - https://georgegarside.com/blog/macos/shu...
and, error code 20- T2 security chip initiated shutdown
UNKNOWN X -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 20
Afgelopen 7 dagen: 108
Afgelopen 30 dagen: 493
Altijd: 104,182
