Ga door naar hoofdinhoud
How to create a Tails Live USB
Wat je nodig hebt
  1. How to create a Tails Live USB, Download Tails OS: stap 1, afbeelding 1 van 2 How to create a Tails Live USB, Download Tails OS: stap 1, afbeelding 2 van 2
  2. How to create a Tails Live USB, Download and install BalenaEtcher: stap 2, afbeelding 1 van 1
    • Insert the USB flash drive into an available USB port on your computer and launch Etcher.
    • In Etcher, click "Flash from file" and select the Tails ISO image you downloaded earlier.
    • Select the USB flash drive as the target device.
    • Double-check to ensure you have selected the correct drive, as the process will erase all data on the selected drive.
    • Click "Flash!" to start the process. Etcher will copy the Tails OS to the USB drive.
    • Once the flashing process is complete, safely eject the USB drive from your computer.
    • Etcher should do this automatically, however it is still good practice to check that the drive was ejected properly.
    • Insert the Tails live USB into the computer you want to use.
    • Restart the computer and enter the boot menu by pressing the appropriate key during startup (usually F2, F12, or Delete).
    • Select the USB drive as the boot device from the boot menu.
    • Tails will start, and you'll be presented with the Tails Greeter screen.
    • Follow the on-screen instructions to configure language, keyboard, and other settings.
    • Once completed you will be able to use your computer in a secure and private live environment. Your online activities are routed through the Tor network for anonymity.
Conclusie
Creating a Tails live USB using this iFixit guide provides you with a secure and private way to use Tails OS on any computer without leaving traces. Remember to always use Tails responsibly and respect the privacy and security it offers.
7 andere personen hebben deze handleiding voltooid.
Jacob Mehnert
44.583 Reputatie
51 handleidingen geschreven
iFanatics Lid van iFanatics
Community
63 Leden
219 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 47
Afgelopen 7 dagen: 277
Afgelopen 30 dagen: 1,262
Altijd: 19,591
