Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
You will be using Carbon Copy Cloner for this guide. Cloning a Hard Drive or a Solid State Drive is about as easy as it gets with CCC. Sadly, CCC is only available to macOS users and is not compatible with Linux or Windows. Sometime soon I will create a guide for Windows and Linux users.
Gereedschap
Geen gereedschap opgegeven.
  1. Download Carbon Copy Cloner from the Bombich Software Website.
    • Download Carbon Copy Cloner from the Bombich Software Website.
    • Install it onto your macOS based computer. You will need administrator privileges later, as well as to move CCC into the Applications folder on your computer.
    • You can download it here.
    • I used CCC 5 for this process and if the user interface changes in the future I will promptly update the guide.
    Aaron, Please post the version info for the app you used.
    Dan - Antwoord
    @danj Edited. Good idea, thanks!
    Aaron Cooke - Antwoord
  2. Once you are at the main screen of Carbon Copy Cloner, insert your SATA based SSD/SSHD/HDD into your enclosure and plug it into your Mac.
    • Once you are at the main screen of Carbon Copy Cloner, insert your SATA based SSD/SSHD/HDD into your enclosure and plug it into your Mac.
    • Under Source Disk, click your current HD/SSD. For example, my current drive is named "Macintosh SSD".
  3. Next, select your Target Disk. My target disk is named "Ubuntu". Your disk can have any type of name ex. "Pie".
    • Next, select your Target Disk. My target disk is named "Ubuntu". Your disk can have any type of name ex. "Pie".
  4. Lastly, click Clone.
    • Lastly, click Clone.
    • Enter your administrator Username
    • Enter your administrator Password
    • Then finally, click OK
    • This process can take up to 4+ hours depending on your disk size, so have some patience!
Conclusie
After you finish, install your new Hard Drive/Solid State Drive and test if it works. If it does not, try cloning again. If it still does not work after that, leave a comment and I will try my best to support you.
17 andere personen hebben deze handleiding voltooid.
Aaron Cooke
22.583 Reputatie
21 handleidingen geschreven
NIWOTech Lid van NIWOTech
Community
0 Leden
0 handleidingen geschreven
I have used CCC for years and years. It is an excellent program!
When upgrading MAC OS to a new version, I always clone a drive before starting the upgrade.
Mal - Antwoord
What if you have several volumes on each disk ? Does it scan the entire structure and boot options ?
Fran Werttt - Antwoord
CCC clones per volume, not per disk. So you have to clone each volume on their own, how many are bootable?
Jelan -
I have tried cloning my 2012 Mac book pro with a vector ssd sata111, my Mac does not see the disk when I connect with usb or caddy, this is getting frustrating anyone has the same problem where you mac not seeing the ssd drive
thank you
Peter
Peter - Antwoord
What about using Restore on Disk Utility read on web that this in itself a cloning method don’t have to go for 3rd party apps
GBish - Antwoord
Unfortunately that method has some glitches for some users. (Like myself) see error OSStatus error 22
Diana Fred -
I’ve used Restore from Disk Utility and it worked very well. First boot with Cmd-R held down. Make sure to Unmount internal and external drives, then select Restore blank drive from old one.
Friedemann Brauer -
Thanks for writing the guide! Will this clone be ready to once I insert the clone drive in? Should I make a boot disk?
Peter Innes - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 49
Afgelopen 30 dagen: 225
Altijd: 8,109
