Ga door naar hoofdinhoud
How to clear Lexmark Intuition S505 paper jam
  1. How to clear Lexmark Intuition S505 paper jam, How to clear Lexmark Intuition S505 paper jam: stap 1, afbeelding 1 van 2 How to clear Lexmark Intuition S505 paper jam, How to clear Lexmark Intuition S505 paper jam: stap 1, afbeelding 2 van 2
    • Lift the scanning unit.
  2. How to clear Lexmark Intuition S505 paper jam: stap 2, afbeelding 1 van 2 How to clear Lexmark Intuition S505 paper jam: stap 2, afbeelding 2 van 2
    • Check the duplex unit, located at the rear of the printer, for any paper obstruction. Pinch the top button to remove the unit.
  3. How to clear Lexmark Intuition S505 paper jam: stap 3, afbeelding 1 van 1
    • If there is any paper stuck inside, remove it. If not, snap the unit back onto the printer.
  4. How to clear Lexmark Intuition S505 paper jam: stap 4, afbeelding 1 van 1
    • Check the front slot, which is located underneath the LED display. If there is any paper, remove it.
Conclusie
Once the paper obstruction is removed, your printer should print smoothly without any problems.
Omar
111 Reputatie
2 handleidingen geschreven
Cal Poly, Team 18-38, Regan Winter 2013 Lid van Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Leden
8 handleidingen geschreven
Één opmerking
Mine still says paper jam but there's no paper stuck in it all. Can you suggest other probs and solutions?
Debra Collis (Debbie) - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 1,639
