Inleiding
The XLR connector connects the microphone to the XLR cable which sends signal to the speakers. It is critical that the XLR connector of the microphone is working properly for your microphone to work.
Wat je nodig hebt
Using a small flat head screwdriver, gently turn the retaining screw at the bottom of the microphone counterclockwise until it stops or provides resistance.
Using a detailing brush, gently brush the pins and inside walls of the microphone.
To reinstall the XLR connector, follow the Installing Shure SM58 XLR connector guide
To reassemble your device, follow these instructions in reverse order. After cleaning the connector, your microphone is ready to connect to XLR cables.
Één andere persoon heeft deze handleiding voltooid.
