Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
  1. Fold fine grit sand paper over a credit card.
    • Fold fine grit sand paper over a credit card.
  2. Rub credit card with sand paper up and down vertically inside the game cartridge port.
    • Rub credit card with sand paper up and down vertically inside the game cartridge port.
  3. Nintendo Switch-kits
    Een snelle oplossing die je weer mee laat doen
    Koop Switchkits
    Koop Switchkits
  4. Blow out game cartridge port using a can of compressed air.
    • Blow out game cartridge port using a can of compressed air.
    • Warning: Do not turn the aerosol can upside down as you spray.
  5. Rub a Q-tip dipped in rubbing alcohol along the pins of the cartridge slot to remove any remaining debris.
    • Rub a Q-tip dipped in rubbing alcohol along the pins of the cartridge slot to remove any remaining debris.
Eindstreep
9 andere personen hebben deze handleiding voltooid.
Erik Bjornstrom
686 Reputatie
3 handleidingen geschreven
Cal Poly, Team 3-29, Regan Fall 2010 Lid van Cal Poly, Team 3-29, Regan Fall 2010
CPSU-REGAN-F10S3G29
4 Leden
11 handleidingen geschreven
It worked! I didn't expect it too but it did! Tried it on two old Sega Genesis systems and hooked them up and I haven't had a problem.
Hilary - Antwoord
All you need is a slightly worn paper fingernail file. Up & down. Back and forth 1 time. In 6 1/2 years I've never had a console come back to my store. 500 consoles & 10,000 games.
Michael - Antwoord
I have a sega genesis 1 the only thing i cant get to work are the conteollers all of them arent connecting i checked the pins and they all look fine. I really want this to work so i can play zombie ate my neighbors
laslidco - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 46
Afgelopen 30 dagen: 243
Altijd: 26,586
