Ga door naar hoofdinhoud
How to clean the Sega Genesis game port
Wat je nodig hebt
  1. How to clean the Sega Genesis game port, How to clean the Sega Genesis game port: stap 1, afbeelding 1 van 1
    • Fold fine grit sand paper over a credit card.
  2. How to clean the Sega Genesis game port: stap 2, afbeelding 1 van 1
    • Rub credit card with sand paper up and down vertically inside the game cartridge port.
  3. How to clean the Sega Genesis game port: stap 3, afbeelding 1 van 1
    • Blow out game cartridge port using a can of compressed air.
    • Warning: Do not turn the aerosol can upside down as you spray.
  4. How to clean the Sega Genesis game port: stap 4, afbeelding 1 van 1
    • Rub a Q-tip dipped in rubbing alcohol along the pins of the cartridge slot to remove any remaining debris.
Eindstreep
11 andere personen hebben deze handleiding voltooid.
Erik Bjornstrom
829 Reputatie
3 handleidingen geschreven
Cal Poly, Team 3-29, Regan Fall 2010 Lid van Cal Poly, Team 3-29, Regan Fall 2010
CPSU-REGAN-F10S3G29
4 Leden
14 handleidingen geschreven
4 opmerkingen
It worked! I didn't expect it too but it did! Tried it on two old Sega Genesis systems and hooked them up and I haven't had a problem.
Hilary - Antwoord
All you need is a slightly worn paper fingernail file. Up & down. Back and forth 1 time. In 6 1/2 years I've never had a console come back to my store. 500 consoles & 10,000 games.
Michael - Antwoord
I have a sega genesis 1 the only thing i cant get to work are the conteollers all of them arent connecting i checked the pins and they all look fine. I really want this to work so i can play zombie ate my neighbors
laslidco - Antwoord
Worked great for my Sega Genesis Model 2 console (which was super flaky before). Also cleaned my cartridge contacts with rubbing alcohol on cotton swabs, made a HUGE difference. Thank you for this.
fcjohnson65 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 152
Altijd: 36,479
