Inleiding
The bottom half of the phone will need to be disassembled, see "replacing logic board" for instructions to remove logic board.
Onderdelen
Geen onderdelen nodig.
  1. Remove the back panel by pressing up on switch, located at the top on the back of the phone.
    • Remove the back panel by pressing up on switch, located at the top on the back of the phone.
    • You may want to use a plastic opening tool to help pry the back panel off.
  2. Unscrew the four 4.5mm screws located on the back plate.
    • Unscrew the four 4.5mm screws located on the back plate.
  3. Remove the rubber screw cover using your fingernail.
    • Remove the rubber screw cover using your fingernail.
  4. Unscrew the 4.5mm screw located underneath the rubber cover.
    • Unscrew the 4.5mm screw located underneath the rubber cover.
  5. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  6. Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
    • Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
    • The panel should come off without much effort.
  7. With the back panel removed, the motherboard should be fully exposed.
    • With the back panel removed, the motherboard should be fully exposed.
  8. Remove the camera and volume buttons and place them in a safe spot until reassembly. Remove the camera and volume buttons and place them in a safe spot until reassembly.
    • Remove the camera and volume buttons and place them in a safe spot until reassembly.
  9. Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard. Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
    • Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
  10. Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone. Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
    • Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
  11. After removing motherboard, the phone will look like this.
    • After removing motherboard, the phone will look like this.
  12. Grab the corner of the rubber key pad and lift out slowly.
    • Grab the corner of the rubber key pad and lift out slowly.
  13. By using a small standard screwdriver and a fine, thin, soft cloth you can clean in between the keypad to remove dirt and debris. By using a small standard screwdriver and a fine, thin, soft cloth you can clean in between the keypad to remove dirt and debris.
    • By using a small standard screwdriver and a fine, thin, soft cloth you can clean in between the keypad to remove dirt and debris.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Joe Cavaletto
101 Reputatie
1 Handleiding geschreven
Cal Poly, Team 11-23, Maness Winter 2011 Lid van Cal Poly, Team 11-23, Maness Winter 2011
CPSU-MANESS-W11S11G23
4 Leden
10 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 2
Altijd: 849
