Ga door naar hoofdinhoud
How to clean the SAECO Incanto SBS Spout
Wat je nodig hebt
  1. How to clean the SAECO Incanto SBS Spout, How to clean the SAECO Incanto SBS Spout: stap 1, afbeelding 1 van 3 How to clean the SAECO Incanto SBS Spout, How to clean the SAECO Incanto SBS Spout: stap 1, afbeelding 2 van 3 How to clean the SAECO Incanto SBS Spout, How to clean the SAECO Incanto SBS Spout: stap 1, afbeelding 3 van 3
    • Remove the spout by pressing the button on top and sliding it towards you.
    • Unscrew the two PH#1 screws on the back of the spout.
    • The spout halves should now separate easily but light prying might be necessary.
  2. How to clean the SAECO Incanto SBS Spout: stap 2, afbeelding 1 van 3 How to clean the SAECO Incanto SBS Spout: stap 2, afbeelding 2 van 3 How to clean the SAECO Incanto SBS Spout: stap 2, afbeelding 3 van 3
    • Remove the spring of the pushbutton. Relaese the Button and remove the black insert off the cup filler.
    • Push off the metal chrome part.
    • Clean it with a small brush and rinse it under water.
  3. How to clean the SAECO Incanto SBS Spout: stap 3, afbeelding 1 van 2 How to clean the SAECO Incanto SBS Spout: stap 3, afbeelding 2 van 2
    • Reinstall the metal part on the back cup filler part then insert the black piece.
    • Hold up the black part a little for pushing in the Button.
    • Then click it trogether and push in the spring.
  4. How to clean the SAECO Incanto SBS Spout: stap 4, afbeelding 1 van 2 How to clean the SAECO Incanto SBS Spout: stap 4, afbeelding 2 van 2
    • Click it together, put in the two screws and you are done. :)
Conclusie
3 andere personen hebben deze handleiding voltooid.
Schwarzstein
2.813 Reputatie
13 handleidingen geschreven
Één opmerking
I just relocated my Saeco Incanto Classic, there's power in the outlet but no power is going in to the machine. What could be the cause?
Ada Ruzza - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 43
Altijd: 6,084
