Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Eject the disk tray from the DVD player before removing power supply.
Remove 3 screws running along back edge of case cover.
Remove 2 screws from each side of case cover.
Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player.
Locate the 4 screws securing the disk drive assembly. There are two on each side.
Use a narrow screwdriver to remove all 4 screws.
Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
Grasp the bridge above the wheel and push the tabs on the side as shown.
Pull down firmly and away from the laser housing.
Be sure to wash your hands before cleaning the optical laser lens.
Grab a microfiber or eyeglass cloth and gently brush the lens.
