Ga door naar hoofdinhoud
How to clean a rusting Microwave
Wat je nodig hebt
  1. How to clean a rusting Microwave, Prepare the surface: stap 1, afbeelding 1 van 1
    • Unplug the microwave oven.
    • Clean the surface of all grease residue with alcohol or acetone.
  2. How to clean a rusting Microwave, Remove the rust: stap 2, afbeelding 1 van 1
    • Remove the glass tray and roller ring
    • Remove the stuck rust with steel wool.
    • Wipe away any debris with a dry cloth
  3. How to clean a rusting Microwave, Apply the paint: stap 3, afbeelding 1 van 1
    • Shake the tin
    • Apply a thin coat with the brush
    • Give the paint at least 6 hours to dry
    • Apply 1 or 2 more coats as appriopriate
  4. How to clean a rusting Microwave, Replace tray: stap 4, afbeelding 1 van 1
    • Allow time for the paint coatings to dry properly, ideally overnight with the door open.
    • Replace roller ring and tray. Plug your oven to the power outlet.
    • You are now ready to use your microwave oven again!
Eindstreep
20 andere personen hebben deze handleiding voltooid.
Tristan Hill
579 Reputatie
1 Handleiding geschreven
4 opmerkingen
Thanks so much!!! I got a small microwave from a rental unit ( it was rusted ans I thought i would be excellent for my fishing cabin ( in the wine country ). I WANTED TO USE EPOXY OR ENGINE PAINT!!! The mention set so many individuals at multiple sites off to saying things about toxic fumes and other ridiculous things. there’s even a special paint Amazon sells!!! https://www.google.com/search?client=fir...
wgcormier - Antwoord
So Easy thanks
Janet Jones - Antwoord
Thank you for the information.
Marci B Jeffcoats - Antwoord
Where do I buy the special paint
Diane Sauchuk - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 81
Afgelopen 30 dagen: 269
Altijd: 61,696
