Inleiding
Corrosion usually occurs in the battery compartment. It appears as a light blue coating on any metal components and prevents power from flowing in the camera.
Onderdelen
Geen onderdelen opgegeven.
    • In this guide we will be referring to 'left'and 'right' as though the camera's front (the part that says Nikon) facing you.
    • Use a quarter to twist open the one large screw on the bottom case. (No picture available.)
  1. Pull up on the tab to remove the batteries.
    • Pull up on the tab to remove the batteries.
    • Note: The batteries will probably fall out of their holder.
  2. MacBook-reparatiesets voor batterijen
    Vanaf $69.99
    Buy Now
    Vanaf $69.99
    Buy Now
  3. Your camera should look something like this.
    • Your camera should look something like this.
    • Clean the marked areas with a cotton swab soaked in CLR or vinegar.
  4. Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
    • Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
  5. All cleaned up!
    • All cleaned up!
Conclusie
Reinsert the batteries by following the instructions backwards. If it's still not getting power, head over to our battery compartment replacement guide. Note: It may be tough to find replacement parts.
3 andere personen hebben deze handleiding voltooid.
Zachary Phillips
205 Reputatie
5 handleidingen geschreven
Cal Poly, Team 25-26, Garner Spring 2011 Lid van Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Leden
7 handleidingen geschreven
Één commentaar
Wow it working thanks for assisting me. I used vinegar to clean my camera so it working now
lazarusmolai - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 17
Afgelopen 30 Dagen: 38
Altijd: 12,057
